Oreo rolling out?
Installed, cache cleared. All good.
A couple things that I feel went backwards:
The Moto "control panel" circle widget. No longer has the high/low weather and battery sides. Now there isn't an easy way to see what the mod battery level is. But it's also much easier to turn off the battery mod. I liked being able to see the onboard and outboard battery % on the home screen.
Yep, they renamed it to Time & Weather instead of Command Center. Now it's like the widget on the Moto Z2 and Moto G series. I think the "Command Center" stuff was Droid brand specific, and Verizon & Moto are moving away from anything Droid related.
That is certainly plausible.
A quick Google search for the Droid command ce nter, and I've got it back.got the v3 version. No root, not a patched apk, just works like it always has. :)
No... I won't post the link. It was way too easy to find.
It also doesn't identify the city you're in. Not that, at home I don't know where I am! But when traveling, especially overseas, it was cool to see the identified area (and also know that then widget was actively picking up local weather.
Where did they move the cache to in the settings? I can't find it anymore.
If you mean how to clear the cache partition it's the same as its been. If you're talking about clearing app caches in storage there is no longer a bulk way to do that. You have to go into each app and clear each apps storage manually.
BrüZZi
