Oreo rolling out?
New message for me but no update yet.
Some things to remember too - as with any big update make sure to clear your cache partition after the update. Battery life and responsiveness may be worse immediately after the update. Allow a couple days for everything to settle down and really see how things are working.
Got my update about 3 days ago. Started installing by itself... took a long time to complete.
All seems to be working well. Noticed a few icon changes and some other changes.
Phone: S7 Edge
One thing I have noticed is the nav buttons are more washed out. Not as vivid as before.
Update should take 20 minutes or so. You should never update with less than 50% battery. Better yet do the update while plugged into a charger. :-)
Installed, cache cleared. All good.
A couple things that I feel went backwards:
The Moto "control panel" circle widget. No longer has the high/low weather and battery sides. Now there isn't an easy way to see what the mod battery level is. But it's also much easier to turn off the battery mod. I liked being able to see the onboard and outboard battery % on the home screen.
BrüZZi
