Yes if you do the OTA update you would lose root. Your apps, info and such would be ok.
If your looking to update to 2.2 and want to keep your root, you should check out "Sprints Lover Rom" over at XDA. Its basically a stock and rooted 2.2 rom with very little change in how it looks or runs. Its been cleaned up and optimized a bit to run a lot smoother. Here's the link: [ROM] 02/25/11 | SPRINT LOVERS | 2.2 | 3.70.651.1 | Radio/Wimax/PRI All-In-One - xda-developers
Sent from my MIUI havin, Gingerbread Throwing EVO
Ok, so if I run the OTA the only "bad" thing it will do is unroot my phone? But it should install properly? Just wanting to make sure. I can always reroot later if need be.
