OTA update auto downloads
Simple answer is to change or update you're ROM. I know the Roms that are Sense 4 based won't have this problem.
Sent from my ADR6425LVW using Android Central Forums
Are you suggesting that a sense 4 rom will work (run the update) or that they would not try
(as documented)?
- - - Updated - - -
(as documented)?
So I have only rooted, I haven't installed another ROM. Can I go ahead and install the OTA firmware? Will I need to root again?
(as documented)?
- - - Updated - - -
(as documented)?
What I'm saying is if you have a sense 4 rom on you're phone the ota will stop trying to install because the phone will not have what the ota is looking for to install itself into. It's looking for sense 3.6 and won't find it.
liquidsnake757
