Overclock Optimus V: Post Benchmarks, Mhz, ROM & Kernal
All these over clocks... Do you just mess with the max speed or do you increase the min speed as well?
Sent from my VM670 using Tapatalk
You can set both minimum & your maximum Mhz. For instance set your minimum down for when your screen times out & you are not using your phone. Doing that will conserve your battery. Set your maximum at the highest stable Mhz you can achieve w/o your phone self rebooting/freezing.
CM7
Kernel: 2.6.32.33-aospCMod
864mhz
Data2ext4 enabled
Linpack (high/low): 11.088/9.53
Quadrant: 1100+
AOSP 2.3.3 / CM7 (Gingerbread) OverClocked @
768Mhz
Governor:
Interactive
Apps i used to benchmark and readings
Antutu total score :
1145
Quadrant :
1004
Linpack
Mflops: 9.03
Time:9.28 second's
can i go higher because if i do it usually crashes the highest ive gone 806 Mhz and crash instantly
AOSPCM7 @ 600/768
Quadrant:
1018
Linpack:
8.8999 MFLOPS
9.42Secs
Norm Res 5.68
Precision 2.220446
Aosp cm7
Oc @ 806
Linpack - 9.55
Quadrant - 1001
How are y'all getting 1200-1300+? And how do I get data2ext? Does it actually help performance?
Right now, I'm testing picasticks-07a on MobiusROM R1 "Green Hill", overclocking it to 806MHz max/480 MHz min while using the interactive governor.
Quadrant score: 1329
SetCPU Short bench: 369ms
SetCPU Long bench: 6689ms
SetCPU Native bench: 2262.719971ms
Linpack MFLOPS: 9.739
Linpack Time: 8.61s
Overclocked to to 825MHz while on the charger using the performance governor.
Quadrant score: 1355
SetCPU Short bench: 339ms
SetCPU Long bench: 6538ms
SetCPU Native bench: 2204.286621ms
Linpack MFLOPS: 10.005
Linpack Time: 8.38s
They're either enabling stagefright or mounting quadrant system files. I benchmark on quadrant usually 1000-1100. Then I mounted files and enabled stagefright and scored 1900. Stagefright is a glitch and mounting system files is a trick. Neither improve anything.
Someone top my system:
My phone can't make calls and constantly freezes, but at least I have a high quadrant score :D
whats your linpack, cant cheat those
But linpak doesn't have a cute graph I can photoshop....
I'm actually more interested in battery life and efficiency than peak performance. I'm not doing much 3D gaming on this.
ROM: aospCMOD 2.3.4 5-26-2011
Overclock: 787 Mhz on Interactive (On 806Mhz it barely goes up)
Quadrant Score: 1064
Linpack:
MFLOPS: 8.741
Time: 9.59 Seconds
Norm Res: 5.68
864 Mhz interactive
Quadrant:1226
Aosp 5/31.
I got that a few minutes after I restarted my phone. It goes down after the phone heats up to around 1159.
Got a consistent Quadrant score of 1109-20 OC'd at 806.
aospCM7-VM-20110531
At 806 for Quadrant, 829 for Linpack...really whatever it could run at. I have a 32Gb Kingston class 4 SD card, so overall results are influenced by that.
aospCM7-VM-20110531
jb804490
