Package disabler pro issues on s8+
xxx JeNeSaisQuoi xxx
Active member
Oct 19, 2015
34
I just had to switch from one S8+ to another S8+ (broke screen). I installed my previously purchased package disabler Pro (along with that weird engine plugin they once added), but now it doesn't disable anything. It wanted me to download some other plugin, which I did, but it didn't change anything and keeps asking me to do the same thing... The app has ALWAYS worked flawlessly on the S8+ I just switched from... Any suggestions?
I believe the older version of package disabler Pro no longer works and it was removed from the play store. The developers created a newer version. If you have a copy of your Google receipt showing the original purchase, email the developer with that receipt and they will send you an unlock code to download the new one which should hopefully fix your issues.
I'm assuming you're sideloading from the developer's site. The Playstore version is worthless.
al3azim: I wrote to them yesterday, but I haven't checked my email to see if they wrote me back yet. It's a good idea though; I hope that it will work...
DsM: yeah, Google store has several and none of them I would even bother downloading. It was from developer site, but for some reason it just wouldn't open... I mean it would open and close or glitch... I tried to use the APK file from my old phone, but, to my greatest disappointment, it didn't work. Takes me through the same path, unfortunately...
I gave up on getting the new app for the old one that was removed, I just bought the newer one without the add-on app. works fine. the back and forth with the developer cost me more hassle than just buying the new one 🤗
dkpiper
