Package disabler ?
Maybe 'cause I'm new but what is the point of that? Just to keep an app from running if you accidently tap the icon?
Don't want to worry if I hand my phone to a coworker, them seeing an app I don't want them to see.
Still can't find a good solution to this other than using apex launcher which allows you to hide apps
Secure folder try
Secure folder try
Second on Secure Folder.
mustang7757... I remember on my Note 8 you use to able to assign a fingerprint separate from your usual one that would take you directly to your Secure Folder from lock screen... is that still possible?? I’m not seeing where it is anymore or they took that away.
I'm not seeing it also but can have different password/pin
hmm... I have to check if I am really curious but I don't think you can set if you enter diff password/pin at lock screen it would know to go to Secure Folder rather than your normal home screen. I didn't use it much but it could work out as a perfect incognito guest mode... you unlock with your secure folder password and unlocks to a home screen people think is your regular home screen and you can walk away and let them use it without concern of them sneaking a peek at emails or apps, etc.
Too bad if they did remove that option.
Yeah I have mine set as different password from lock screen, still can't get into it from lock screen.
I wish Samsung would allow guest mode like my Google and one plus phones
I just installed Alliance Shield X but you have to register/sign in to use it. I went through that procedure and have not received an email confirmation as yet so can't log in and thus... can't try it yet! Hmmm...
I use both, I know some members reported PDP with the dev , but I've had great experience with them , I had a issue over the weekend with it and sent a email and within 30 minutes got it fixed.
NVK
