thewraith420
- Sep 6, 2011
- 1,987
- 223
- 63
What rom are you on? I'm on Bobz ICS with the afterburner theme.
My sig... I've seen it that way on quattrimus too
Tapatalk'n it from my VM670 running LS670ZVJ Dante Rom
I have it on good authority the Torch passed the Optimus V port to a guy who hasn't got a clue what he's doing...
Wow for real is that how it went .....
Has anyone got that mms fix in the link to work? All I could get was phone fc
Supposedly someone got mms working, but only partially, sends ok, receives only when having full bars of service.
But that was 1 of the only reports I can remember of it working.
sent from my un-dead sammich.
I can send fine with gosms but receiving doesn't work
I can live without MMS, I mean yea its really nice to have, but you can just tell people to send to your Gmail, and use the Gmail app to view it.
At least Mms is half working.
Not exactly. If you get a 99999999 message, how do you know who sent it?
Button swapping doesn't seem to be working for me at all. After installing the rom and using the patch I keep having my menu and my home buttons reversed.
You wouldn't get a 9999999999 message if its sent to your email. Their number will appear, ie 602741xxxx@pixmbl.com and it would have the mms attachment, you then use your Gmail app, or other email app, to open and view what they sent to your email, and download it to your phone if you like.
I meant, you get a 9999999 message, but who do you tell to send yo your email if you don't know who sent it?
Which rom? And which patch, and what firmware are you running?
So I've been thinking we've got the source code for mms.apk and the source code for what's needed to make it work. Why not make an virgin mobile mms.apk?
It can be built on froyo sources so that everyone can use it and can be used in any rom.
Isn't it the apn-conf.XML that needs changed?
Joylicious_Optimus, and I'm not sure, whatever the default is for OV.
Sent from my NookColor using Tapatalk 2
