[Patch's]ZVJ to ZVD & ZVD to ZVJ Flashable zips(Optimus V)
Ohh. CM9 and 10.... They will need different patches. They use different framework.jar's :(
Yea, that's what I'm trying to avoid, too many patches can cause confusion..
I already maintain 6 different patches, 2 for the Optimus S, and 4 for the Optimus V, 2 being specific for Drew's CM10 ZVJ JellyBean ROM to be fully functional on the V (ZV4,5,9) (one with 2sd-ext scripts, one without).
sent from my un-dead sammich.
Its impossible to make a universal patch with my knowledge. Unless we can get one of those things were you get to pick when installing like on the HD2....
Once there is a method to get MMS working tho we could bring the fix to the rom dev's attention and maybe they would keep the patch up for their rom..
Tapatalk'n it from my VM670 running LS670ZVJ Dante Rom
@thewraith, BobZhome does not like MMS fixes. Once I figured out how to implement them into ROMS so they're not another download, I told BobZhome and he didn't want to add it into his ROMs. But he did fix it in his newest build. Not with a flashable though.
Sent from my Optimus M
Well obviously it'd be at the dev's discretion. Who knows.... Perhaps a way to integrate it Into a rom but not break the native mms already working...
Why does the title say ZVJ to ZVD but there is only a ZVD to ZVJ zip available to download....
I see a link to your thread, two links to fix mms, and a link at the bottom to switch from zvd to zvj... am I blind?
Both patches are in this thread, and to fix MMS is only by following directions that the link takes you to.
I see both in tapatalk, and on the web set.
I think you need your eyes checked :p
The devs won't really care, no. But I think LeslieAnn might be some help. She's liek, the smartest person out there. :)
I'm not crazy. I just went on a PC and it's there all right but there's an empty space on tapatalk... stupid tapatalk
Has anyone got that mms fix in the link to work? All I could get was phone fc
For me it looks the same as Anthony screen
Tiokujha
