[SOLVED] Persistent intermittent network loss after using International Pass
Victor Suarez
51
23
8
I recently used the T-Mobile 30-day International Pass for a two-week trip. While away, my network connection was hit-or-miss. I assumed the issue would resolve once I returned to the U.S. and reconnected to the home network, but the 'searching for service' or dropped signals are still happening. I have already tried resetting network settings and restarting the device. Any suggestions on a fix?....FYI: I also getting a "insert a SIM card" msg when i go to my messages.
Ok -- since you already tried a Reset Network Settings without success, I figured that the next step would be to talk more with T-Mobile, since it sounds like more of an issue on their side. Let's see if anyone else here has an idea. Good luck!
Reactions: Victor Suarez
I’m happy to report that my issue has been resolved! I reached out to T-Mobile support and walked them through all the troubleshooting steps I had already tried. After I mentioned that I was getting the 'Insert a SIM card to continue' message, the tech determined it was likely a faulty physical SIM card.
We switched my line over to an eSIM, and everything is working perfectly now. A huge thank you to B. Diddy for the help and BerryBubbles for the input!
heritagevines30
