phone battery drain after gear s2 update
MrSaturdaynite
After days of back and forth with at&t I was finally able to get numbersync to work correctly. Apparently there was an update released through the gear app that addressed the numbersync connectivity issues. Welp as soon as I got that fixed , I began having a serious battery drain issue on my note 4. Am I the only one experiencing this? Is there a known solution other than tossing all the equipment in my fireplace!?!!?
Re: Battery drain on phone after gear update
My best advice is to backup your device to your computer using Titanium Backup or Kies. Then do a hard reset (Makes it as if you got a new phone). Then from where you did your backup, restore the data back onto your phone. Hope I helped!
Posted via Samsung Galaxy S5 model SM-G900A running 5.1.1 AT&T
jeromepare89
