Phone charging rapidly and slowly on same charger.
There is no notification. But on the bottom of the lock screen, it will show current charging mode, e.g. charging rapidly, charging slowly or just charging.
You can also see this info in settings app.
Thanks, I tried your suggestion and learned that the notification about the charging rate is there. I just couldn't see it because the lock screen is so dim, I couldn't find it. Is there a way to brighten the lock screen?
I thought you were looking for an actual notification like an alert. The lockscreen does not have a brightness adjustment.
It is an indication of charging mode, not actual charging rate. That is, for the same charger, wired or wireless, this indicates what kind of charging mode the phone charges on and it won't charge for the duration of the charge process even though the actual charge rate will automatically change based on the charge level. Specifically, above 90%, the phone will show down the charge rate dramatically.
So, no need to stare at it all the time. The lock screen typically is in a low light black & white ambient mode that is meant to prevent screen burn in. If you tap the power button, it will switch to full color mode with regular brightness.
There have been so many iterations of change in bettery information display since my post. There is no point to argue about it.
Jamie789
