Phone does not call after clicking contact.
I had that all weekend. I was at a soccer tournament in a weak signal area. It drove me nuts. Never tried direct dialing because I was driving (I know I know) once I was in a better signal area it has worked fine ever since.
Sent from my EVO using Android Central Forums
yup, very annoying. happens to me and my friend too. i remeber my old htc hero had the same issue. seems like this is a recurring issue w/ htc phone. i am sure there are different work around for this, but why settle w/ work around w/ something as basic as making a phone call?
I have had both the phone and texting issues. I did a simulated battery pull and that cleared the issue up. To do the stimulated batt pull hold the power button for about ten seconds after u get the power of airplane mode the bottom buttons will flash and then u will get a countdown on your screen. I had to do this twice but no lag issues since.
I continued having this problem for a couple of weeks. Then I saw an error message saying my "assistant" app closed unexpectedly...Which wasn't even running. I uninstalled it and all has been well since.
Any new fixes? I have the same problem. I am doing the battery pull 1-3 times a day. It's incredibly aggravating. This is the last time I will ever buy an HTC.
Apparently the method listed in the following thread has fixed the issue. I have actually followed the steps and everything seems to be working fine so far. I have not had the issue yet. Additionally, I have not turned back on Facebook contact sync yet. Let us know if this fixes the issue for you.
http://androidforums.com/htc-evo-4g...ngtone-issue-fix-8-29-12-a-2.html#post4989279
hi, you are right some app is doing this. But how do we find out to delete which app. I have already did a factory reset . it was fine. again it started now with same issue .
This thread has been cleaned up. Please keep the discussion civil and ontopic. Thank you.
Jennifer Stough
Forums Moderator
For things that require fine touch like this i guess I just always assume it's my sausage link sized fingers as to why my touch isn't clicking the right thing.
ok I had the same problems,, calling and texting ,, is weird. but I installed on app called CLEAN MASTER , I clean the cache and do all other programs ,,now it works great ,, when I do have a problem I used it again and works ,,, hope this helps
maryhurst515
