Phone keeps trying to install gear vr
I had this issue as well thinking it was connected to a VR headset when I didn't even own one. It would pop up so often my phone was useless. I couldn't even send a text without it popping up. I reset my phone back to factory and it still had the issues saying connected to charger or a VR when it wasn't.
I took it to a Samsung store and they sent it away to be fixed. Took about 8 days, they said it was a fault with the USB port and they replaced it under warranty.
Unfortunately i bought my phone in Dubai and directly from a little shop for cash - i doubt it would be an easy process to have the phone repaired.
This really sucks because it's clearly a software problem. Even if it's originally a hardware problem, it's still triggered by some kind of software roll out that was done. It should be reversible, we just need Samsung to recognise the problem.
So last night after using my portable battery pack for just a few mins my phone tried to install samsung gear vr and now it wont stop trying.
It keeps connecting and disconnecting to a charger regardless of if a charger is connected or not. Sometimes it indicates that its connected to a dock.
Ive tried restarting the phone, wiping the cache, disabling samsung vr processes but doing so only lasts for a few mins before the malfunction happens again.
My solution was to factory reset again, wait for all the operating system updates, and then install apps after, it appears as though it may have been a corrupted update that caused it all, but thats just my guess.
Anyways, its been a few months, i stopped using the case with a magnetic kickstand, installed andriod 5 marshmallow and now, no problems..
Just out of curiosity, do any of you with this problem have developer options turned on? I ran into the same issue with the phantom charging and gear vr install pop-ups. Was on chat with support for around 2 weeks back and forth to little or no avail. I thought back to what I had recently to the phone. Then I realized I had tried to sign up for one of the samsung promotions that requires your build number and other phone information. I tried to copy and paste the info from the settings on the phone and after tapping on build number trying to get the copy/paste pop-up to come up, something unexpected happened. I was told that developer options was activated. I looked into, but thought nothing of it as I didn't change anything in the settings. Shortly thereafter my phantom problems started popping up. I tried everything and lastly gave into a hard reset. No problems since then.
-Russ
tl;dr
phantom charging popped up after enabling developer options.
I didn't do anything with my note 5 before i started having problems. I reckon they rolled out some update and the software conflicted with hardware or something. The docking and charging issues stopped after about a week and it would charge normally with a cable, but the biggest problem that i had was when i received a call, the person on the other side couldn't hear me - i'm guessing because the phone was confused about being docked and being attached to a phantom headset. I tried to clear the cache and even do a full reset but nothing helped so i eventually returned it so it's in for repairs. I've bought a S7 in the meantime and am loving it.
Important to mention that my note 5 was a dual sim variant which is apparently made in Vietnam or something like that. I didn't see the marshmallow update until a few weeks ago so perhaps my variant of note 5 was last due to being a minority. Anyways, i'm convinced that it is a software problem but i guess it's too random for samsung to be blamed outright and therefore i doubt they will take responsibility. Just hoping i get my note 5 back it was only 6 months old!
I had the same issues as everyone is describing a few months ago before the Marshmallow update and it went away until last week when started again. It was so bad I had to power off the phone because it would beep like it was connected to the charger about every 3 seconds. I ended up getting a replacement and I'm pretty sure it was a hardware issues with USB charging port and not software.
I tried that app to disable everything and it stopped the charging issue but I still had the problem with people not hearing me during calls. Which tells me the phone was still confused into thinking a headset was connected. Still think it's a software issue
I tried this too, only worked for a couple days then the phone started charging and not charging constantly instead of bringing up the gear VR screen.
Only solution was to get a new phone.
I have noticed that my Note 5 got affected by the same issue after a forced update that i have reluctantly accepted followed by google and youtube update. After that:
1. My normal charger and cable could not charge phone fast
2. A blue ring followed a brief vibration would appear as if you connect phone to micro usb for a charge while you not connecting anything.
3. Battery life has become very short
4. Screen would turn black and then blue with Gear VR install prompt when i have not downloaded.
I did manufacture default reset, flashed phone by Samsung Hub at local Best Buy and now it is going to be replaced with Refurb. I am disappointed and think that this is not a phone but Android app bug that triggered that. Any input from Android folks?
smith-jhone
