Phone screen won't turn off while charging
My developer options are off and it is still showing display continuously
Gail,
Have you looked in the Developer options on your tablet to see if there's a similar setting? Perhaps if you posted this in the relevant forum you'd find someone that has already posted the detailed steps for your device.
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM 10.2 using Tapatalk 4
Not sure if its the same for the S3 but try this go into settings, find developer options should be under the category systems, then look for stay awake if ur phone won't shut off while charging it will be checked just un check it then should be fine.
Thank you so much. This is old but you helped me out.
Winnie
