Question Phone sound stops abruptly and call ends after 1 ring
Sohag360
4
I have a Realme 9 4G phone. The sound of this phone stops for a brief moment and plays again. The media doesn't pause, just the speaker goes off. I tried connecting an earphone but the problem is still there. I tried Bluetooth earphones as well with no luck. The sound stops abruptly no matter what.
Another problem is, I cannot make or receive any call with the phone. The call cuts after 1 ring for both incoming and outgoing calls.
I tried changing different settings and followed a lot of tutorials from YouTube only to be disappointed. As a final solution I tried hard resetting the phone but the issue is still there. Not sure what is causing this issue, any idea?
Did you try Safe Mode yet?
You may also want to speak to your carrier about replacing your SIM card, because SIMs can become faulty.
I'd say the likelihood is pretty high, considering that it persists in Safe Mode and after a factory reset. You could take it to a repair shop, but it may not be worth the cost ...
TheGreatApe00
