Phone storage problem. plz help!!!
henrykim
4
so today I justed manually updated my fascinate to Froyo (EB01). After encountering into some problems, I got it to work. I got all excited that it worked and went to market to download some apps. Suddenly a window pops up and tells me that I don't have enough space for the app. I went to the settings and found out that my internal phone storage is at 0. I do not have any app in my phone. Can someone please tell me what happened to my phone or tell me how to fix this problem? please help.
yeah the problem was that you most likely had a voodoo kernel installed and never disabled lag fix before flashing EB01
You will have to Flash THIS with odin, you will lose all apps and data
its a stock non rooted version of EB01, it is a very thorough version that will rewrite almost all the essential parts of your phone and it should fix the internal memory problem
Reactions: henrykim
Thank you so much! It worked like magic. My phone is perfect now!!!
very welcome, now you can leave it as it is or you can flash one of my odin packages, im working on Adrynalynes 2.6 so if you wait 20 mins you can flash it
uhm... what would that do? XD
it will do alot, xoom boot animation, removes almost all verizon and samsung software, custom launcher, custom lock screens, give you root, give you clockwork and a whole bunch of other stuff
all the changes are listed in the first post here
http://forum.androidcentral.com/ver...s-hacks/53810-rom-superclean-2-6-updated.html
my odin packages can be found here ill be adding 2.6 soon
http://forum.androidcentral.com/ver...ged-roms-w-root-clockwork-updated-2-25-a.html
Reactions: henrykim
