Phone stuck in fastboot mode
A better way to don't remove battery :
Android Multi Tools v1.02b
- connect phone / tablet to PC run program then press 9 . Exit Fastboot Mode
Good Luck!
I have Micromax A311..I tried to factory reset the phone but stuck in fast boot mode.
Can U help?
Hi, fastboot mode engineer here. Did u try resetting ur device (reset button on the backside of the tablet)
I tried everything still I m stuck with the fastboot screen
Thanks!
It's needed 2 times to type fastboot continue but it worked!
Really?!
Thank u.. my mobile also had the same issue.. I hold the power button more than 10 second and then phone gets automatically reboot..
It didn't work out for me
I am stuck. I typed in whatever it said to and it says it was turned off but now it just goes to the screen with Motorola on it vibrates and then turns off again. It stays on about 4 seconds and turns off for 4 seconds. Can you please help me
Good Luck!
Hello,
my tablet got off battery while stuck on fastboot mode. What can I do???
Please help!!!
guys need help i accidentally closed the tool during my fastboot, my phone is still in fastboot mode ..what will i do?
tnx
Re: Phone stuck in fathis worked for mestboot mode
1.Download adb fastboot
2. Connect the device to pc
3. Open Terminal in adb folder
4. type: fastboot devices
5. if you find your device type fastboot reboot
this wprked for me
BigHugh
