A
AC Question
My phone was stuck in Ultra Power Saving Mode! I Fixed it! However as I was stuck I was trying to find a way to fix it and I couldnt! Hence why I am posting this thread.
Its very simple!
1) Go on your internet app (That should still be there)
2) Search APK Nova Launcher (Or any other preffered launcher)
3)Download the APK and install
4) After installing, go to your home screen, You should be prompted to choose the launcher you want to use
5) Select Easy Mode or whatever your default is for when you got the phone
This should bring you back to the original UPSM menu screen, at the top right click "More" and then "Disable UPSM)
You're welcome
Its very simple!
You're welcome
