Phone temps a bit too high?
tisasecret2
Hey guys,
Received my G3 yesterday and I've set it up with CM12.
I've been noticing that the phone has been getting warm with using Youtube or recording videos at 1080P.
On youtube my CPU is at 125F and battery is at 92F.
On video recordings my CPU is at 150F and battery is at 103F.
I idle at 97F CPU and 79F battery.
Do you guys have temperatures similar to this?
Where do you see the temp? I can't see any on my end but mine doesn't feel warm at all when watching YouTube nor video recording.
If you download CPU-Z that will show battery, HWMonitor is another app that shows both CPU and battery.
In HWMonitor sensor 0-10 are for the CPU as far as I know.
EDIT: I do definitely feel a bit of warmth on YT, it's not hot to the point where I can't touch it. But there is definitely heat around the top of the phone.
Those are perfectly fine temperatures. The phone is going to get warm, it's 3,000 MaH and 2.5Ghz with no fans.
Omar Boresli
