PIN Required on Restart
Well that may be how you see it but to be honest -- That is how it is going to be from now on. They want things to be more secure and believe the phone needs the PIN the first time. Honestly it is only on a restart and you shouldn't be doing that too often.
Mine sometimes requires the PIN even when it hasn't restarted. I see it as a way to reduce the "I forgot my unlock PIN" posts. I can't believe the number of people that forget those.
Doesn't it have something to do with the encryption? I could be wrong.
I believe you're right.
The PIN or pattern is required because that's how the phone is able to access itself. It uses that PIN or pattern to decrypt the phone's storage. Without that security feature, it's impossible to start the phone. A fingerprint doesn't work to decrypt the phone. Once you've decrypted it, then you can use your finger print to unlock it.
Also, for clarification, the 6P was never on Lollipop, so there was never a time that the 6P allowed you to unlock the phone with a fingerprint after starting up. Other phones may have done this, but you'll find that Apple devices work the same way as the 6P, where you need the PIN before you can unlock the phone, and the reason is exactly the same.
I think the better question is why are you restarting your phone four times a day. That seems fairly excessive and I can't see any reason that would be necessary.
If his phone is like mine, we aren't restarting it because we want to, it's because the phone crashes. I get a random reboot at least once a day.
I just switched to a 6p a couple of weeks ago after using a 5x for a few months. I did not have to enter a PIN upon restart for the 5x, and the setup was the same (software, fingerprint ID, etc.). I don't have any issues with this on the 6p - it is nice in fact - but I was curious as to why it is different.
Then I would suspect you have a rouge app causing issues. I typically end up restarting my 6P every so often as it never seems to reboot on its own; it has been extremely stable for me (other than the Awake issues caused by the GasBuddy app).
If I remember correctly you can just enter the wrong PIN several times and at some point it'll prompt you to use your Google password to unlock the device; then you can reset your PIN.
Most features have the ability to disable or adjust how they function. This one really needs to follow suite. After reading other posts on this issue I've gone through the hassle of unlocking, decrypting and rooting my phone only to find these prompt is still there. Nothing is more annoying than cruising down the highway using your phone as the GPS, enjoy an unexpected phone reboot and now have to fiddle with my phone at highway speeds (or almost worse, find a place to pull over) just to unlock the damned thing and get back to my course. Security 'features' like this should be an option (even if hidden in obscure menus), not the defacto, it's my phone, not my password vault or desktop.
I thought android is meant to be a alternative to apple, being able to customise a phone to the individual liking. Android 5 was but android 6 is starting to become like Apple. An individual should have the right to choose which method to unlock the phone on startup.
Steve Jobs is laughing in his grave. Android is starting to adopt apple methods and over time will be swallowed up by Apple. ....
Sorry, but I'm not sure how you arrive at that conclusion based on this security feature. Having to enter your PIN/password/pattern unlock is only after a reboot or cold start. This does not equate to Android becoming Apple, in my opinion.
For more information, see this help page under "Use your fingerprint": https://support.google.com/nexus/answer/6285273?hl=en
If you're talking about using a fingerprint to unlock the startup sequence after rebooting, that is a terrible idea. Not only is it less secure (because a fingerprint reader isn't foolproof) than a password, numeric code, or even pattern, you can be compelled to unlock your phone with a fingerprint. The same is not true about the other methods.
It'll be kind of bad if I crash my car trying to restart my GPS navigation system.
There needs to be an option to disable this.
Is it because the phone is randomly rebooting? That should be the main focus, rather than trying to disable a security feature. Have you tried to narrow down what might be causing the random reboots?
While I'll agree that may be how it's supposed to work I think it's clear from this thread that folks (myself included) are still experiencing random prompts to enter a PIN/pattern/password without the device undergoing a reboot or power cycle.
For me it doesn't happen as often as it used to but I still see it once a week or so.
That Google support link also mentioned a few other instances where the PIN/password/pattern might be required:
  • When your fingerprint isn't recognized after a few tries
  • After restarting (rebooting) your device
  • After switching to a different user on the device
  • After more than 48 hours have passed since you last unlocked using your backup method
That last one might be why it seems to pop up randomly.
[*]After more than 48 hours have passed since you last unlocked using your backup method
That could certainly be it since I exclusively use the fingerprint sensor unless otherwise required. Thanks!
then what to do if i forget the unlock PIN
after wiping data , may i use the phone or it needs reinstallation of android os.
no matter what personal data will remains or not.
If you forget the PIN I thought after multiple attempts you'd be given the option to use your Google password to reset it. I could be mistaken.
At worst you could perform a Factory Reset and start from scratch.
Welcome to Android Central! If you forget the PIN, and it doesn't prompt you for your Google password after multiple unsuccessful unlock attempts, then you'd probably have to do a hardware button factory reset (which will wipe the data from your phone). Remember, though, that if your phone has Lollipop or above, you'll still have to enter your Google account and password after the reset, before you can proceed with the Setup Wizard -- this is because of Android's Factory Reset Protection feature. So I hope you didn't forget your Google password as well!
I'm actually having a real Secure Startup bug I think. When I first set up my phone, I turned on Secure Startup. After that, I would always have to enter my password twice when my phone turned on, once to actually turn it on, and again to unlock it. I then updated from Marshmallow to Nougat. Since then, I've realized I no longer want Secure Startup because I can never set updates to install overnight because once the updates are complete, my phone won't turn on until I enter my password, which means my alarms won't go off in the morning. It's inconvenient for me to find time to do these updates in the day, so I really want to disable Secure Startup so I can have them install automatically while I sleep. I went to my settings to try and turn it off, but I found that it already was off. I tried toggling the button multiple times and turning the phone on and off, but it still requires my password to turn on the phone. I even tried getting rid of my PIN altogether, but when I tried to turn it on I still had to enter my old PIN to get in. Anyone know of any solutions for this possible bug?
Adekanmbi
