Pixel 6 Pro seems to be running warm when idle
FF22
1,949
1,952
113
I don't think it is just my feelings. The 6 Pro appears to be running warm to the touch. Yesterday's first day, it also appears that the battery was running down faster than I expected. I see it is at 96F (35.5C)
Any app using an unusual amount of battery in the battery stats? How's your cell signal?
Gaia used 13% (mapping yesterday's bike ride)
Now Google-Fi used 1% BUT "Mobile Network" used 50% - not sure what the difference is?
My Cell signal bounces between full triangle to half full triangle.
The Mobile Network being that high would suggest poor cell signal -- is the indicator full for the most time, or is it more often half?
Also, is wi-fi on all the time? That might mitigate some of the issue.
In the past, I've also found that a simple reboot can correct this kind of thing.
Hmm. I see "Internet" is using wifi, rather than cellular. I've never noticed that in my Pixel 3.
Getting ready for another bike ride. Check in later (g)
uOttawaGrad_22
