Pixel Fold Android 14
Well, @Bkdodger1 suggested something Google's Tech support did not. Google wanted me to Factory Reset the phone and restore and HOPE that I would then be offered Android 14. I was really reluctant to go through the entire restoration process.
What @bkdodger2 (aka bkdoger 1 :p ) suggested was to install the BETA. That worked. And I think it took less time than just ordinary system updates. So, I now have Android 14 even if it is beta
Reactions: Bkdodger1
You’re official now ..I have two logins with past issues with this forum hehe
Reactions: FF22
Update just hit for the quarterly
Android 14 QPR1 Beta 2.2 (November 2023)
This minor update to Android 14 QPR1 Beta 2 includes the following fixes:
Fixed an issue that sometimes prevented devices from receiving calls. (Issue #298747690)
Fixed an issue where tapping or long-pressing a Quick Settings tile sometimes failed to launch the corresponding app or settings menu. (Issue #302147272)
Fixed an issue that sometimes caused the Settings app to crash when checking for system software updates. (Issue #303739210)
Fixed an issue that prevented Device Mirroring from working correctly with Pixel Fold devices. (Issue #302003079)
Fixed an issue that sometimes prevented the system settings for large screen user per-app overrides from loading.
Fixed an issue that sometimes caused the Camera HAL to apply the wrong tuning profile when an app requested a certain camera mode.
Fixed an issue that sometimes caused the system UI or device to crash if accessibility magnification mode was toggled rapidly.
Fixed an issue that sometimes caused the package installer to crash due to a null pointer exception.
Fixed an issue that sometimes caused the system launcher to crash due to a null pointer exception.
Fixed an issue that interfered with Bluetooth and Wi-Fi connectivity until the device was rebooted.
Fixed issues with Face Unlock reliability.
Fixed an issue that sometimes caused the device unlock animation to stutter.
Fixed an issue that sometimes caused the screen to flicker when transitioning from always-on display mode to the lock screen.
Fixed an issue that caused the animation to display incorrectly when a user gestured to open the notification shade.
Fixed an issue that sometimes caused the system UI to crash or consume more memory than necessary.
Fixed an issue that caused the picture-in-picture window to stop displaying with rounded corners after locking and unlocking the device.
Fixed an issue that sometimes caused device-to-device transfer data to be saved to an incorrect account.
Fixed an issue that caused some UI elements to render incorrectly when the device font scale was increased.
Fixed an issue that sometimes caused the work profile badge for an app icon to be displayed in the wrong place while viewing the list of recent apps.
Fixed an issue that caused some text to display in the wrong colors when always-on display features were enabled.
Fixed issues that sometimes caused a device to crash and reboot.
Fixed an issue where additional power was still being consumed by mobile network connectivity even after a device connected to Wi-Fi.
Fixed an issue where audio failed to play back or was interrupted if Adaptive Sound was enabled.
Fixed issues with audio playback when using spatial audio.
Fixed an issue that sometimes caused Wi-Fi service to be interrupted and fail to connect until the device was restarted.
Fixed an issue where the battery level in the status bar sometimes displayed temporarily as 0%.
Fixed an issue for Pixel Fold and Pixel Tablet devices where the "All Apps" button on the taskbar was slow to appear immediately after launching an app.
Fixed an issue for Pixel Fold devices where the lock screen was sometimes still displayed if the device was unlocked and unfolded at the same time.
Fixed an issue for Pixel Tablet devices where a primary user's live wallpaper selection would sometimes be overridden after a secondary user selected a different live wallpaper.
Fixed an issue for Pixel Tablet devices that caused an unsmooth animation when tapping to return to an app from the list of recent apps.
Fixed an issue for Pixel Tablet devices that caused audio to pop when adjusting the volume if a wired headset was connected.
Fixed an issue for Pixel Tablet where a user was returned to the Home screen instead of the app that was open when the device was locked if they unlocked the device using their fingerprint while a screen saver was active.
Fixed an issue that caused memory corruption in rare cases.
Fixed various issues that were impacting system stability, performance, and connectivity.
All eligible devices enrolled in the Android Beta for Pixel program will be offered an over-the-air (OTA) update to Beta 2.2.
Update incoming
Reactions: mustang7757
Update incoming
I heard they will implement the toggle to turn off at a glance in beta ?
Just looking at my pixel 8 pro and Fold on Android 14 no beta it has the toggle also , I have to find the article I read maybe they meant to remove at a glance on pixel launcher and use one of its other widget, thanks though.
I switched to the Pixel launcher to find the setting...let me check my P8P
I see it on my P8P for the Pixel launcher removing from home screen
Battery standby has been excellent today. I took it off the charger at 7 am and it's now 5:39 pm and I have 85%. I haven't used it much as I have been in AWS class all day but with about 45 minutes of use. Still I don't think it's bad. Oh and that 45 minutes has been all inside screen.
Excellent I'm happy with mine ...I have my SIM in my P8P but will be swapping by the weekend
Adekanmbi
