Play Store Program Updates Problem
After clearing the cache and data, the update(s) will download and install after I go back to the play store and click on update all. When there are more updates, the cache and data need to be cleared again before clicking on update all.
Weird. Can you clarify -- when mustang7757 suggested clearing the cache for Play Store Services, was it Google Play Services that you cleared?
These 2 need clear cache and force stop also uninstall updates try.
It was both Google Play Store and Google Play services. I'll clear both again, uninstall updates, force stop, and see what happens.
Even if it still doesn't work, I really want to thank the two of you for the help and ideas that you have given.
After these steps (last night), went to the Play Store, had a couple of updates, clicked on update all, and they downloaded and installed. This morning there were a couple more updates, clicked on update all, and they just changed to pending. After clearing the Google Play Store cache and data, went back to updates, clicked on update all and they downloaded and installed. A full wipe of the phone would probably fix this, but I'm not going there, I'd rather just clear the data/cache when I have updates.
Thanks again.
Thanks again.
The other thing I wanted to ask you , do you have it set to auto update apps?
It's set for "Over wi-fi only".
You could try use both data and wifi just in case your wifi giving a problem, just a suggestion to try.
Other thing is can erase your Google account and re add it see if that helps also .
Got it set for wifi and data. If I remove my google account and add it back, will I lose any critical settings/configurations?
Thanks. If the change to wifi and data doesn't do it, next step will be to remove the google account and add it back.
There were a couple of Play Store updates and still had to clear the cache and data to get them to download and install. Was waiting on the 1CSC1 update to see if it might help. So far it seems to have helped. I've had two different rounds of Play Store updates, and after clicking on update all, they started downloading and installing.
Thanks again for all the help provided in trying to fix this.
Keep us posted that way we know what the fix is , thank you
That was short lived. Now it's back to needing to clear the Play Store cache and data before the updates will download and install.
mostafamu
