please help android razor wont turn on!!!!!
otterpops2
My android razor wont charge or turn on. Also, the light in the corner doesn't turn on as well its not red or white it shows no color. It was working perfectly fine yesterday put it on the charger last night and this morning it was off tired turning it on and nothing. its been on the charger for the past hr now. what do i do. Please someone help
First, take a couple of breaths and relax.
Have you done anything to your phone regarding rooting or flashing custom ROMs on it or where you running it 100% stock? Stuff like this is very important for us to help you and the more information that you can give us will be beneficial.
If anything, try a force reboot on your device. Hold down the vol up and down and power at the same time. If you phone boots up, you should be okay. Try that and let us know what happens.
Welcome to AC!!
Have you tried holding down the power button for a while (30 seconds should be more than enough). I've had that fix my Prime when it wouldn't turn on.
Also, do you have another charger you could try? Perhaps the charger is busted and the battery is dead.
This is why I hate non removable batteries
Seems like this is the way devices are going, but, I agree with you, it's really a shame. I have three extra batteries for my X2. I doubt I'll be able to do this with my next phone. :'(
