- Dec 27, 2015
- 1
- 0
- 0
I got S4 M919 T-mobile. I tried to root using iroot program. It rebooted and stayed in loop. I can access stock recovery and download modes only. I tried wipe cache partition, factory reset but problem continued.
I tried to install Stock ROMs M919UVUAMDL_M919TMBAMDL_M919UVUAMDL_HOME.tar.md5 and M919UVUFNB4_M919TMBFNB4_M919UVUFNB4_HOME.tar.md5 using Odin different versions. Odin always says
<ID:0/007> Added!!
<ID:0/007> Removed!!
<ID:0/007> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> M919UVUAMDL_M919TMBAMDL_M919UVUAMDL_HOME.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/007> Odin v.3 engine (ID:7)..
<ID:0/007> File analysis..
<ID:0/007> SetupConnection..
<ID:0/007> Initialzation..
<ID:0/007> Get PIT for mapping..
<ID:0/007> Firmware update start..
<ID:0/007> SingleDownload.
<ID:0/007> sbl2.mbn
<ID:0/007> NAND Write Start!!
<ID:0/007> FAIL! (Auth)
<ID:0/007>
<ID:0/007> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
I could install CF-Auto-Root-jflte-jfltexx-gti9505.tar.md5 using Odin. It is a success.
Can I try Fenny-UVUFNB4-STOCK-ROOTEDv1.2 rooted stock room and try to install from recovery?
Please help.
<ID:0/007> Added!!
<ID:0/007> Added!!
<OSM> Please wait..
<OSM> Leave CS..
<ID:0/007> sbl2.mbn
<ID:0/007>
Please help.
