Please help unbrick my Nexus 10
arjen82
Active member
Jun 6, 2011
32
Hi guys,
After the last OTA security update on my (unrooted, unlocked) Nexus 10 (5.1.1 (LMY49H)) it refused to boot (stuck on the Google logo). I logged into recovery mode and tried to wipe the cache partition. Connected the tablet to the charger and left it overnight. The next day it was still busy wiping.
So I rebooted (long press the power button) and tried the wipe data/factory reset option. Again, after hours of running still not done. But now I couldn't even get into recovery mode anymore (when booted into the bootloaded and selecting recovery mode the tablet starts a normal boot and gets stuck on the Google logo).
Last software option I could find was using the WugFresh Nexus Root Toolkit v2.1.4; but sadly again no option I tried completed.
Some hardware things I found that worked for some was tapping on the back and opening it up and making sure all connections are okay (as far as you can actually check this on modern electronics). Did both, but still unable to boot past the Google logo or enter recovery mode.
Any help would be much appreciated. But I am guessing that the tablet is dead. Seems to be a hardware issue (memory not working properly anymore?).
Kind regards,
Arjen
Hi guys,
Kind regards,
Arjen
Welcome to Android Central!
You can give the Google route a try using ADB to push it to the phone. Other than that, that may be the last method I know of to try to recover it.
thanks for the suggestion. Sadly the same result; the tablet is just unable to complete the wipe of the data.
My Samsung Nexus 10 is dead after the 5.1.1 update....I tried wiping the cache memory but that did not work and so took it to a Samsung repair centre here in Toronto. They said that they've not been able to solve the problem with the 5.1.1 update....some kind of hardware issue...and said there is no fix....our tablets are goners. We should start a class action suit!
Is this the April security update? That just downloaded on my tablet, now afraid to install! My Nexus 10 is already running 5.1.1 tho, should I be worried about this OTA update?
liquidsnake757
