Please help!!
Didnt mention how this happened. I was looking through xda on ics and came along sense with ics rom. Because i saw the link on the evo 3d section i quickly assumed it was for the evo. I ended up flashing this rom but when i booted it back it would just go black with the menu buttons lite up. Concerned i went back to the link and found out it was for the sensation not the evo. Thats when i couldnt get back into recovery..
You just need to use this tool and your issue will be solved: http://forums.androidcentral.com/ht...nstalling-twrp-recovery-1-1-1-all-hboots.html
(I do this all the time by mistake, lol)
Boot to hboot... Run tool... It will repalce your recovery....
See the sensation mount points are one lower (or maby higher) than the E3D so when you flash a sensation ROM you destroy the recovery partition with the data partition from the ROM (or something like that).
EVO28312 here is your fix:
Yeah, what he said.
Reactions: anon(502805)
milkycoins here is your fix
Download ruu ZIP here: http://www.scottsroms.com/downloads.php?do=file&id=20
Reboot to hboot
relock the bootloader using this command "fastboot oem lock"
reboot to hboot again by pulling battery this time.
Go to recovery
Rename downloaded file to PG86IMG.zip
Mount USB storage and copy the file over
pull battery again
reboot to hboot and it will scan file and flash it.
Then unlock re-install recovery and you can go from there.
Download ruu ZIP here: [ZIP] - RUU_Shooter_S_Sprint_WWE_2.08.651.3 - Downloads - Scott's ROMS
Reboot to hboot
Go to recovery
pull battery again
Thank you so much! I will PM you if i have any questions tomorrow. You rock!
Reboot to hboot
Go to recovery
pull battery again
I relocked the bootloader and booted back into hboot. Now i cant get into recovery and under "Relocked" it says "Security Warning"
Here would be my plan of attack...
Flash a ruu zip file. You can find one here: [ZIP] - RUU_Shooter_S_Sprint_WWE_2.08.651.3 - Downloads - Scott's ROMS
That should clear it up. You have to flash it via hboot, not recovery.
If you are HTC "unlocked" you need to relock it first or it wont flash.
You do this with fastboot.
Hoep that helps. I am going to bed... Newboyx will understand everything here and can help you get through the steps if you dont know how.
If yo dont get it tonight send me a PM and I will help you....
Take it easy.
My problem is i cant get into recovery. Im stuck at hboot and cant flash anything
Scrosler and newboyrx...i cant thank you guys enough. Finally booted back up the stock sprint rom. Gonna do the rest tomorrow. You guys are life savers. Thanks again!
Great!!! That makes sense! One question though once i download it to my sd card does it automatically fix the recovery from hboot or is it giving me an extra option from hboot
You download the tool to your desktop, and unzip it there. Then follow the instructions from the thread.
Glad it worked out. If you need anything else feel free to ask.
Yeah, thats basically what I am suggesting...
I didint realize there were two different issues... I am going to make a post to clarify....
Yeah o guess someone else is having a problem too and he took over my post. But you guys are so great and figured out both our problems. Thanks to everyone helping out!!
Did you get it to flash the recovery?
All i did so far is download the two zip files. Not sure though what version of twrp i was using
chatgpt
