pls help..urgent
do you have the terminal emulator in your app drawer? If so, type in "su" enter key and see if the "$" changes to "#"
Joe,
I got it to the point where I have all permissions enabled and almost apply apex but it tells me its not verfieid and kicks me out...
I tried redownloading the zip again and recopying it..maybe it got corrupted..no idea..
im going to try again..
keep you posted for sure!
Hey phil,
Did you get your phone to work? While playing with various roms I've gotten corrupted files so I know that could be the problem.
Just a note this should be located in the hacks and roms subforum. I usually skip over the main forum and other rom fanatics may do the same. If you post in the hacks forum it's more likely that someone will have had the same problem and it will take less guesswork to help you
I need some assistance. From my Droid X home screen when I selected the telephone and then contacts on the next screen, when I brought up the keyboard a contact search would automatically begin with relevant results. Now when I select the keyboard nothing happens and no search ensues. Can anyone help with this problem?
I just checked on mine and everything worked fine. Are you running all stock or are you rooted with a rom?
All stock, no rooting. I push the phone icon from the home screen, next is the phone screen, I push contacts, then hold the options hard key until the keyboard appears, then start typing, then nothing happens, no search results begin to show up. I can't find a setting and power off/on doesn't help. any thoughts?
New Android user questions I have?
I just purchased an Android device. I understand the new Android 2.2 is coming out soon. Can I upgrade my device that has ver. 2.1 to the 2.2.? Apparently it will make my Metropcs Huawei faster and add new and improved applications. Where do I start to get this done. I do understand that using Z4root will jailbreak the phone. Is rooting part of the process I need to complete beforehand? As you can see by my questions, I am very new to this and trying to learn as much as I can. Any help will be great appreciated.
SaakalSEO
