Poor Man's 4G toggle
No one needs to download a separate app.
To set 3G only:
1. Go to Phone
2. Enter the following: *#*#4636#*#*
Using an app eliminates 12 of the 13 keypresses in these 2 steps. Of course it's your call, but I prefer 1 click to 13. :)
I am not able to connect to 3g when accessing the test menu through the Phone or when using Phone Info. I am able to change the setting to CDMA auto (PRL), but it doesn't connect.
Is anyone else having this problem?
Interesting. I'm not having this problem but a friend is and she's about ready to can the phone over it.
It leaves voice connection fine but there is no data connection.
HTC would win a lot of respect if they just provided a widget. Probably take one of their devs 15 minutes tops.
I was having the same problem. I discovered that I had to restart my phone after changing the setting in order for it to connect to 3G. Give that a try and see if it works for you.
I'd rather they spend the 15 minutes (plus) working with Verizon engineers to make the switch between 3G/4G and battery drain work. IMHO, we shouldn't have to be switching, but this is a nice way to do so in the interim (hopefully, it is just an interim).
Not to be a jerk (Seriously) but this thread is four months old. The latest MR2 update has a very easy way to switch between 3G and 4G in the Mobile Network menu now, there's no need for the #*#*4636*#*# method anymore, or for other apps to do it for you.
Was thinking the same thing!
yanis
