Portable Mobile Charger 1900mAh
Lorenzo Pilastro
Hi all,
I've just bought a mobile charger with the following specifications:
CAPACITY: 1900mAh
INPUT VOLTAGE: 5,25V
OUTPUT VOLTAGE: 5,25V
INPUT CURRENT: 500mAh max
OUTPUT CURRENT: 800mA max
It also says that it is compatible with Blackberry & V8 Interface devices.
Ebay's seller wrote, in item's title, that it is for Google Nexus 4 phone. Is it compatible, for real? I don't trust this seller :P (especially because he also sent me an Iphone 5 cover instead of a car support for N4.......)
Thanks all!!!
800mAh will charge the phone, but not fast the one that come with the Nexus is 1.2A output. I have a 500mAh one for Bluetooth headphones that will charge the phone if you are not using it. The 800 one you are looking at might be the same, but it will charge if slowly. You really want 1A output or higher. Anything below will charge but YMMV.
liquidsnake757
