Ported S6 Edge from T-Mobile to AT&T and running hot, why?
  • Start date Start date
A
AC Question
I just ported my S6 Edge from T-Mobile to AT&T for work and since porting it the phone is hot to the touch. I looked at other forums that suggested turning off T-Mobile apps that might be using resources searching for service but it's still running hot. I don't want to have to do a reset on my phone because I don't want to deal with all the app reloads etc. Any ideas?
Re: Ported S6 Edge from T-Mobile to AT&T and running hot
Welcome to Android Central! The APN settings are correct, and you're getting good cell and mobile data reception?
Try wiping the cache partition, which can be a helpful general troubleshooting step. No personal data will be lost. https://support.t-mobile.com/docs/DOC-21095
