Post homescreen screenshots taken on your Samsung Note 8!
Samsung theme WP and I forgot the name of the icon pack...the 'experience' skin has been surprisingly useful for me as I usually go with Nova Launcher...
Here's mine, pretty simple 2 hidden folders I like a clean background
Here is my home screen. Still trying stuff out so it will probably change.
I like it. What is the calendar widget you have, I really like that!
I'm curious as to what that calendar widget is as well
Made it with zooper. One module is a series with day of the month and the other is just text for the month. Rotate the text for month to have it to the left. Took some messing around to get it aligned from top to bottom but it fairly easy to do. I could have set the calendar to launch with a tap of the widget but I have a full month widget using aCalendar on my second screen for that so I can see any even through the month. Also using a different samsung theme to have the different navigation buttons which are more stock android. Material Design (Android 7+) is the theme. Nova is my launcher. I love using gestures with it on the home screen and having the google now panel to the left instead of how the stock launcher uses bixby. I set the weather panel in bixby to the top so I at least have a use for that button. I don't like a cluttered home screen so most important things are just a tap or swipe away.
This was my previous widget:
Thanks to you here is my new home screen. Took me a lot of fiddling to get it to my liking!
midastouch15
