Post homescreen screenshots taken on your Samsung S8 / S8+
Found a few good walls on an app called Blacker. Currently on the Play Stores front page. Way to many ads, uninstalled. I like what I found though.
Made some minor changes. Decided to use Dock and using Weather Live widget instead of my usual HD Widgets.
Basically new to Android and having alot of fun :) Amazing what you can customize and multitask with.
Welcome to Android, and Android Central for that matter. And well done. Hope you're enjoying your experience.
Long time since I was active. See username lol
Grabbed an S8! Amazing!
GIF ANIMATED VERSION
Theme applied to galaxy s8 (18.5:9 aspect ratio)
Nova launcher as base with dock disabled.
Background and widget made in photoshop.
Theme (everything seen in the gif) made in Kustom Live Wall paper.
Icons are from the PipBoy White icon pack.
Status bar and navigation bar (soft buttons) removed with Tiles app Inmersive Mode.
As a note, the home screen itslef is completely empty without any real icons or widgets. All the theme is inside the the live wallpaper.
The circular glass screen lightning effects moves trough the gyroscope, to try to simulate how it would react to light.
The screen contents are interactive: Touching the hour opens the clock and alarms app, Touching date opens calendar, Touching the weather icon opens GoWeather, Touching the wi-fi information toggles the wi-fi connection. The external ring composed of dots that rotate shows battery left too.
Touching the lower part of the screen/screen ring toggles GPS Maps mode, alternating between the first menu and a modified version of the MapsMaker komponent.
It has a screen unlock animation in which the screen starts all black then fades into the background starting from the top, but couldnt record it since recorder doesnt record locked screen.
The background image is separated in several layers, so that each layer is easily replaceable in both texture, color and transparency. Textures and colors are all easily manageable from the same menu trough global variables. External backgrounds can be set up too.
http://i.imgur.com/kmQ6Lya.jpg
awesome!
Iknownothin
