Post Your Home Screen v1.1
Official: Post a Screenshot of Optimus V Desktop
Since everyone is rooting and using different ROMs and themes, I thought it'd be nice if we can see what we can compile. Basic idea is to share new ideas and whatnot. I haven't found a thread on it yet so hope this works. I'll start I guess.
OptimusVBoy22 - I like that wallpaper, do you have a link?
I'm new to android, but learning fast thanks to you guys here. Got my V a week ago, and haven't stopped playing with it since. Running CM7, here's my lean and clean Green Machine ADW home screen:
I keep the icons for my most used apps in the hidden dock and a up/down swipe shows them and/or the notification bar:
Using unlock gestures keeps my lock screen nice and clean:
And I use SwipePad to add another hidden launcher:
I used ScreenShot by Gik Soft to take these screen caps (rooted phones only). It allows you to save in various formats, and you set a number of seconds to delay the capture, then navigate to the screen you want to capture. Much easier than trying to hold open SwipePad's hidden dock and shake the camera to capture the screen at the same time (almost impossible).
I use "Picme". It launches an IP address on your WiFi. you navigate to that in a browser and you can take snapshots of your phone from your computer.
My Homecreen Set up
I'm currently using Simi Clock,Simi Folders, Calendr, Juice Defender Widget, Astrid Task manager, Andro Noter, Batt Stat Pro, Audio manager Widget Extended Controls,NewsRob and DoubleTwist Widget
i just bought goto lockscreen. and it doesnt show weather? any clue?
Yeah!!!
And I also made sure I had 'use wireless networks' enabled in location settings.
Maybe it's because I've had no data for 24 hours and I've been on wifi?
lumaplay
