Post your home screens!
Been rocking this one now steadily for 3 days that's a record haha..
Sent from my HTC6435LVW using Android Central Forums
Clock widget and icons?
Clock Widget: UCCW with the Holler! white skin
Wallpaper: Found it on Wallbase
Apps, Phone, Web icons: Text2Icon
Gmail, GTalk, Handcent, Mail icons: Black Glass ASW Theme
Notification Bar: StatusBar+
If you're not using a launcher, you can still change your icons with Icon Changer Free.
Just downloaded like 4 8 icon packs and that UCCW Holler! skin... let the fun begin.
This has lasted me a week or so. Nova Launcher, Glasklart icons, Weather Cards skin on UCCW.
I have decided to use stock for awhile. Sense is actually a pretty smooth simple interface.
Sent from my Verizon Droid DNA
Decided on an Abstract background for now. I feel abstract backgrounds are better on the Homescreen
Sent from my Verizon Droid DNA LTE Device
I can't decide on what wallpaper to use...I'm thinking the second one...
So I'm trying out smart launcher and so far I like it. Its still in a beta stage, but its pretty simple and minimal. It has limited icon choices, but you can choose icons from your gallery, so you can create your own icons, and the free version does not have widget support, but the full version does.
After playing with it a bit, I've found you can change the icons in the flower on the home screen. It is only compatible with ADW icons, and some of them are a little finicky with not wanting to work, atleats the icons packs. Anyone interested should probably download adw themes opposed to just icon packs.
Smart launcher with minimal adw theme for the icons, icon settings set to Holo with no background, and clock set to ics. I am really digging this.
Lightning launcher, vivid icons Sent from my HTC6435LVW using Android Central Forums
I think it looks very clean as well. I know the pro version gives you the ability to add widgets, but does it also allow you to add more screens? Also, how are you liking the categorized app drawer? I'm not sure if that would bother me enough that I would get rid of the launcher but I think it might.
Sent from my DNA
Sent from my DNA
The app drawer was one of my favorite additions to the launcher. I believe it has multi page support on pro version. Ive already gone back to stock, but that was only because I preferred to have folders on my main screen.
I borrowed this wallpaper and basic design from RDXHD over at mycolorscreen and added my own little tweaks.
2 versions:
Sent from my DNA
It's a slow day at work, so I mixed it up again, and I like this one better:
Sent from my DNA
Simple, in the same manner as my past few.
Been playing around with it a bit more. Can't decide what I like the most...this one shows my personality more, but the previous one looks more...balanced.
I preferred the three bar set up with enabled hotspots in the missed it bar. Still messing with the color of it. Ill find it...
DanishDanuu
