Post Your HTC Incredible Screens
maybe i'm missing something, but that only changes the weather widget. it has no effect on the appearance of the clock. from other people's screenshots, they seem to have been able to change the clock more than just the four font choices that are available.
On the very bottom right of the configuration screen is the option to skin the clock and above that a little is the option to skin the weather.
:p thanks. I got all excited! I was thinking "if he bookmarked it it must be working!"
Do you find the battery status pro app to eat your battery at all? some of the comments state that it does.
Yeah no it doesn't work lol.
I haven't noticed a problem and also system panel shows it as not even being a drop in the bucket but then again I've never been without it so I guess I could test it?
You gotta make sure to check for new settings after each update and beautiful widget tend to get a good share of updates that's why its the best weather/clock app on the market. Glad I was able to help coach.
I liked Beautiful Widgets, but found myself going back to the stock HTC Clock/Weather widget... I guess I like the full screen animations... You know, cause... I'm a dork... :confused:
I do the same if I'm running the Sense launcher but most ofter I use ADW where I can;t use the HTC one. And I think its pretty safe to say most of us are dorks :eek:
If you want to... I've been using it almost all day and you are right, it doesn't show up at all in system panel. I'm sure it is less than 1%, not even an issue.
A little change up tonight... the new ADW and ADW.black theme...
i just switched over to "Batteryminder" and actually like it a lot more. it has like 6 different styles and sits in the top left of your notification bar. its similar to the one u have now but with MORE haha UPGRAAAADE and doesnt seem to be affecting battery at all or have negative comments
just DL this. much more functinality and it looks ok but I prefer the look of battery status pro. (like the small green battery)
I'll keep minder for today and see what happens.
Sorry for the delayed reply. Haven't been in this thread for a while.
So I have to ask because I want them, where did you get the dock icons with the lil androids.
I think I found them on XDA. Can't remember where exactly but I can upload a zip of them and get you a link if you want. Let me know.
What calender widget is that?
I just installed Launcherpro and only calender widget I get is a daily agenda.
Thanks!
Also, what size image do you use when creating your own icons for Launcherpro?
The calendar widget is called Pure Grid Calendar. Pay app in the market. I like it cause it's skinable and you can pick different widget sizes.
Not sure about the correct size of the icons for launcherppro, but I was using 48x48 I think. Maybe someone else who knows for sure can chime in.
Here is my latest setup. Now that I got root I have some new icons to put on that 7th screen :p
For a while I slept on the "Magic Smoke" live wallpaper that came with the phone. It's pretty sweet
i feel like a total moron, but i am unable to take a screenshot of my incredible. i've downloaded the SDK and the necessary drivers, but when i plug the phone into my computer it doesn't say it's discovered new hardware and doesn't allow me to search for/install the drivers.
i've also tried these instructions (Tutorial: Droid Incredible screenshot capture - PPCGeeks) and had absolutely no success there either. fairly frustrating and makes me feel very stupid.
thanks. yeah, i've installed SDK. my issue right now is once i connect my phone and trying to install the drivers. the only thing i can think of is the cable i'm using is a charge only cable, so i'll have to retry later with a different cable. otherwise, i guess i'm SOL.
heritagevine08
