Post your jelly bean battery life!
Badow!
Sent from my Samsung Galaxy S3 Boyyyyyy!
This is the best I've done so far. I think I could do better if I really tried. This is just using it like I normally would and not trying to conserve battery. If I dialed my screen down more I could probably do a lot better.
How do you pull up the history and use from the settings menu? I can't seem to figure it out.
Mine runs for days. With normal use. But that's because I use the totally awesome Oonite 4200mAh extended battery. I love this thing. I can play and play and play and play and play and play and play and play and play and play and....
Just wanted to see what everybody is getting battery wise since the update I have been seeing a lot of negative results I still think my batter is pretty good post your screen shots and feel free to give some tips on how to extend
The amazing galaxy s3 :D
My battery life was terrible for the first week. Today it started get better. I'm not sure what changed. I was about to do a factory reset until I saw a turn for the better today. I still may do it just haven't had the time. I have a bunch of apps. I may need to do some winter cleaning :D. Although today I did notice the media server took up about 24% of my battery life. Not sure what that is all about.
Sent from my SCH-I535 using Android Central Forums
Not very good. Lost 35% in almost 4 hours.
My device upgraded and battery life is terrible! It drops to 70% within two hours of little if any use! Also, "Media Server" and "Media" are regularly running when I have never seen them run as often on ICS. Is there something I am doing wrong? Should I factory reset and purge some apps? Please help!
I'm happy with my battery life with jellybean and WiFi with 3hrs of screen time.
Sent from my SCH-I535 using Tapatalk 2
Best day of battery life so far:
Why post when you had multiple charge cycles on there that seems like it would not be a good day.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
It was just like topping off while in the car :) not out of necessity
I can tell but still man those times don't really help.
I have 200 apps not battery problem,you just need then in deep sleep you will be fine. my it single charge not cheating lmao
Lets try that. Ok all day on wireless. About an hour spent talking on the phone.
deedee2
