Post your Samsung Captivate Screenshots!
Changed it up a bit...
How can I get it? Sorry I'm brand new to Android
No problem,
Your going to have to Root your Captivate and then modify a file to allow outside source applications to be installed (since AT&T locked that out). After all that, you just basically google it and download straight on your phone. It will install and your good to go. I havent checked here but there are how-to's on the XDA forums if you are looking into doing that.
Hope it Helps!
No problem,
Hope it Helps!
Awesome thanks!
I'm thinking about buying a captivate tomorrow and was wondering how you changed the bottom from the stock icons to the grouped ones you have there?
This is just using the "app" called launcher Pro. Just install it and mess with the preferences, super easy!
jommy
