Post your Screen!
idk why but it is not installing. am i supposed to remove the original launcher?
HelixLauncher2 (thanks to DA for posting in the application thread)
Second picture has the new weatherbug map widget
Third picture was a home screen on a different HelixLauncher2
is that a beautiful widget skin? if so where can I find that. I have a version like that but the weather is not in the middle. Thanks
Phone is on vibrate, that is HelixLauncher2, stock Gtalk and the battery is charging BTW.
I know Shady is scared of MetaMorph. So here is what it does. ;)
Is your Droid rooted since you're using HelixLauncher2?
man there is a lot to learn with this compared to the ol crackberry. Ive been perusing forums for the last month and picking up things here and there but I think I've got it the way I want it...for at least the next ten minutes
My Droid screens. Rooted Bugless Beast .7 (ESE53) using Flavored Ice Droid Edition 2 theme and SkaggzFont (segoe). Wallpaper is live grass. Also, I replaced the status bar with the Dark Desire Theme (at alldroid)
First screen to the left
Far Left
First screen to the right
Last screen (far right) just has a picture frame widget on it currently. Not sure what else to add at the moment.
whats the bottom widet on the last pic?
what beautiful widgets skin is that?
That isn't a skin. That was before beautiful Widgets changed the layout. It used to look like that but HTC made them change it. I have a theme for beautiful Widgets that is very similiar to it but you can't find it in the ones that are available in the app. Go to droidforums and check out the ones they posted because they have a sense one that you can manually add.
As for the widget that you asked about, thats called audio manager widget. It is free in the market.
Dude, I've looked up and down for a new HTC version and I knew droidforums was hiding one. I'd have to navigate through 100 pages (101 to be exact) to find it. If you have a direct link, that would be awesome.
I don't remember because I downloaded it a while back but ill try to find it in a little bit. I might have the theme file still on my laptop. If it is still there ill try to post it.
here you go trey, i think you can either place it in the Theme folder and extract it there or extract it and then put it in the theme folder.
edit: for the file is too big to post here. if you PM me your e-mail i can prob send it that way
Hello,
I just downloaded Weather Widget donate, and it shows my hi and low temps reversed.
For Example: H 1 degree Low 53 degrees, how do I fix this?
thanks,
SBASF
