Post Your Screenshots!
Question... how do i add data to the lock screen so that people (if it ever gets misplaced) know who to contact and what number to contact...
It's in the "Owner" field. I think you find it in the Security settings. I let my tab drain completely and it's charging now, so I can't give definitive steps. You'll find it, though.
Edit: I'm talking about the Samsung Galaxy Tab here. I assume this is a standard Honeycomb feature.
Finally made it with new lock screen, one main screen and separate side screens :D [was inspired from xda ;)]
Very nice, zytho! Thanks for sharing - it's nice to see created work continually being shared!
Here is my Infuse as of now........ But I see a lot of good ideas in this thread, so it is sure to change...
file.php
file.php
i still cant post mine as no one the screen snaps apps don't work :(
but loving everyone's elses, but i just wish i could mod mine more but that is HTC for you :(
Root your phone... Problem solved :D
Sent from my Gingerbread Speedy 4G using Tapatalk
You don't need to root the phone for snapshots. All you need is the sdk installed and know some basic adb commands. There is a how to on this site, look around for it -- I will post it when I get to a computer to search around.
Sent from my HERO200 using Tapatalk
I think this is the how to your talking about Take Android screenshots without root. Still need root or a custom launcher to customize Sense UI.
IMO, the "hard" part about rooting for most users in installing the SDK and any required driverds. If you are going to install the SDK & drivers, you may as well go with a little extra effort and root your device while you are at it. Then you can take screenshots when you are not in front of your computer.
i just use an app on the market called "ANDROSS" or Andro SS, either way, it uses the accelerameters in the phone, all ya do is shake it, then it captures the screen :P
anyway, here is mine, launcher pro+ using nills buisiness gingersense and Fancy Widgets Pro.
background image is actually a commishion i had done by someone else.
mwahyudi28
