Post your watch face
Yup, it's all functional.
Play Store link-> https://forums.androidcentral.com/e...com.lanhoj.zwskin.zooperweargs&token=ITNcyre0
There's also a trial version-> https://forums.androidcentral.com/e...wskin.zooperwearwearablestrial&token=Oi7ygmwc
Both require the paid version of Zooper Widget to work though.
That's where ya lost me... I bought the Watch Face then realized you needed $2.99 more to run it. I appreciate all developers and their work, but won't pay twice for one end result.
Refunded!
Refunded!
I realize that my App is a little "niche" - since it's primarily targeting those Users that already own "Zooper Widget Pro" or are willing to buy both.
That's why I priced mine (I'm not affiliated with "Zooper Widget Pro" ) as low as possible & also included it in the trial version.
The way you could think of it is you buy "Zooper Widget Pro" & you can then use "Zooper Wear - Wearables TRIAL" at no additional cost & can also create your own designs
Then, if you want more pre-made designs, "Zooper Wear - Gear S" can be a sort of "IAP" or "upgrade".
However, your reaction is completely understandable.
No hard feelings, LoL.
my files----all-----device storage----android----data----kr.co.omnicon.android.appcessory.watchstylermanager.gear3.s
then open the saved design folder and delete the image file
This should do the trick. When you design your watch face do you rename it or leave it with the #'s? Whichever way when you get to the folder it should look like this. Depending on how many faces you made then just open the folder for the face you created and delete the image file that shows the finished face you made and that's it. It should be 2 images one of the background you selected and one that's completed. The completed pic is the one you delete. Then go to the gear app select the watch styler then the watch face and your good.
Actually I removed the app and reinstalled. Loads my images just fine now.
I understand. I Thought you were affiliated! My apologies.... Will you link me out to the Zooper Widget I need to run it??
No worries.
Sure, here's the link to Zooper Widget Pro -> https://forums.androidcentral.com/e...ps/details?id=org.zooper.zwpro&token=oLspjen4
Trial version of my App -> https://forums.androidcentral.com/e...wskin.zooperwearwearablestrial&token=8RMKaHR0
Full/Paid version of my App (99¢ )-> https://forums.androidcentral.com/e...com.lanhoj.zwskin.zooperweargs&token=ekp7_Zdz
Everything else is detailed within the Play Store description of my App.
Here's one of my wifes. Unfortunately though, it is killing her battery life. Its almost dead by 6pm.
Nope, she has it set to 15 seconds. I think I am going to remove both shortcuts and see if it helps any.
Afro Samurai!
Picked up the Christmas Snow Animated clock this morning for $1
25 wallpapers to pick from and it snows on all of them... I wonder what this will do to my battery life LOL
bogorshop
