Power bank capable of adaptive fast charging for the Samsung Galaxy S6/Edge
ilordvader
591
Many people looking for a Power Bank which has Fast charging for there phones,
I found these & if there is any other Please do post links:
~ This has * Qualcomm Quick Charge 2.0 *
https://forums.androidcentral.com/e...e-backup-battery-6000-mah.html&token=LxUWnE3X
http://ape-battery.en.alibaba.com/p...comm_Quick_Charge_2_0_power_bank_MP5200Q.html
~ Wonder if this New Samsung Battery will have a Fast charge
http://www.sammobile.com/2015/03/02...-pack-and-new-colors-for-level-on-headphones/
~ I got this see it on YouTube
iWalk Extreme TRIO 10000 Ultra-Slim Backup Battery Power Bank with LCD Display
http://www.iwalk.net/EN/battery/universal/UBO10000.html
~ This one is very different 1st of its kind i have seen
comes with a option of SD card slot, so it works as a OTG USB in 2 sizes 6000 & 8200mAh
http://www.mymili.com/Product.aspx?id=46&pid=3
~ New Style - PoP’n 2 Charger - Smart Phone & Tablet
http://www.shop.xpalpower.com/index.php?route=product/product&path=69&product_id=493#1432173854
~ BRAVEN BRV-BANK Smart, Ultra-Rugged
http://www.braven.com/outdoor-serie...-rugged-portable-backup-battery-6000-mah.html
~ Advanced power lock technology with standby time up to 6 months after fully charged.
Built in Micro Usb wire & can use the battery as a Stand
Vivis™ Knight V2 10500mAh Dual USB Portable Charger
http://www.amazon.com/Vivis-trade-K...ag=hawk-future-20&ascsubtag=UUacUvbUpU4271327
~ Nice but has slow charge
PhoneSuit Flex Pocket Charger DC OUT: 5V @ 1A
Small size & Charge your Flex and Smartphone at the same time
http://www.phonesuit.com/phonesuit-flex-pocket-charger-android-smartphones
~ Good part is it claims 3A output
Power Core Ultra DC OUT: 5V @ 3A
With our Quick-Charge technology you can power your devices at the fastest rate possible, up to 3.0 Amp.
PhoneSuit Power Core Universal Battery Pack Series
~ I found this which is nice, cos it charges the 10000mAh powerbank in 95min
which is very useful and did not find other Power bank like this:
Ultrapak Fast-Charging Batteries - Products | uNu
~ Good brand & has 2.4A output
Mophie powerstation plus 2.4amp out
atleast get Up to 3x Battery
http://www.mophie.com/shop/universal-batteries
~ Something different
Lepow ADD Detachable Power Bank
http://www.lepowglobal.com/products/add/
~ Coming soon -
ZAP&GO charger
https://www.zapandgocharger.com/
* * * Also want to suggest some other Stuff * * *
Xpower 2.4A Aluminium Alloy Micro USB Cable
http://www.agrade.com.hk/index.php/...inium-alloy-micro-usb-cable.html?options=cart
can also find it on Ebay
Smart & Secure Fast-Charge USB Cable and Adapter
https://www.kickstarter.com/projects/andyfei/smart-and-secure-fast-charge-usb-cable-and-adapter
K’isauve is a battery, SSD, cable in one
http://www.pkparis.com/en/prods/kisauve/
Mu Tablet White 2.4amp out
http://www.themu.co.uk/pages/mu-tablet
CHOETECH 6 Port 60W Multi USB Charger with two dedicated Quick Charge 2.0 Ports Charger with Qualcomm Technology
http://www.choetech.com/choetech-multi-6-ports-usb-charger-quick-charge-2/
Just one point:
The way electricity works, you can't make a phone or powerbank charge faster by using a larger charger. Current isn't pushed into the device, it's drawn by the device, and the device - phone or powerbank - will draw as much current as it's designed to as long as the charger supplies at least enough. A 10000mAh powerbank won't charge any faster if you connect it to a 100 Amp charger than if you connect it to a 10 Amp charger - it's still 1 hour plus inefficiency, which turns out to be about 90 minutes (assuming the powerbank is designed for a 1C charge) from 0 (which you should never do to a lithium battery) to 100%. Neither will a phone. (I charge my phones from a 30 Amp supply when I'm at my desk. They charge just as fast as they do with the appropriate size wall charger. For instance, my Note 3 draws 1200mA - regardless of the size of the charger, unless the charger can't put out that much.)
Just one point:
Thanks buddy thats good to know
When you all get the Galaxy S6 Edge
Please do post what Power bank you got & how long does it take to Fully charge the phone
hoping to get one that charges the Phone within 3hrs :)
I use the Mophie Powerstation XL and it doesn't charge my phone, only slows down battery depletion. Not sure if the problem is with Samsung or Mophie. How long does it take to charge your phone from low batt to full?
janvi33
