Power button instantly locks and PIN lock
Giovanni Rastelli
Hello,
after some update I have an issue with some S4 in our company.
We have not change any policy, "Power button instantly locks" has been disabled but this setting seems to be ignored.
So, every time that device goes in standby or powerbutton is click, screen lock appear, despite settings are to ask pin after 14 minutes.
Anyone as the same problem? (... and a fix) do you know if it possible to unistall this update (don't suggest to factory reset - I know about it..., :( )
Thanks a lot to all
Giovanni Rastelli
Hello,
Thanks a lot to all
Giovanni Rastelli
Well, this seems weird have you tried doing a soft factory rest !! This reset will not remove your data or ..... but what it will do is rest all the settings back to the time when you have purchased your device. See if that works out otherwise I am afraid but you need to do a factory reset !
Miserydhala
