Power button Maxs out volume?
Pseudoty
10
When I press the power button on the right side of my Gnex it makes my volume setting go to max. At first I thought I was accidentally pressing the volume rocker up, but after replicating this several times my fingers are clear of the volume rocker. I have the Verizon silicone case with the oem battery and it is not touching the button. I am running Volume+ so I can hear the ringer but this was happing before I installed it.
I read the known bug thread and did not see this one. Is anyone else having this issue?
Does the problem still happen after a reboot?
Yes. I just tried it even did a battery pull. I have the volume one notch below max then I use the volume rocker to turn the volume down then the power button to turn the screen off but the volume goes back up.
I pretty much have this same problem. It's only happened a couple of times though. Like you, I'm running Volume+ and have the High Gloss Silicone Case.
heritagevine08
