Power button not consistent
johnnyshinta
2,666
22
My power button sometimes doesn't work. I feel it click and the display doesn't turn on. But if I click it a second time it works fine. Has anyone else noticed the power button not working.
Does yours actually click when you push it? Does it make the sound or can you just feel it click? Mine doesn't do either which makes me think you might have gotten a bad one.
Sent from my HTC6435LVW using Android Central Forums
I feel it click but don't hear it. My friends is the same way but he has a case that makes it easier to press.
I took my case off to check it, but it still doesn't feel like a click. I wonder what everyone else's feels like? Anyone?
Sent from my ASUS TF5000T.
Mine has done the same thing. I have held it down and the bottom of the phone flashes for a while...then it just works.
Mine 'clicks' as well although it's not a sound, you just feel it. Accurate every time, I actually went into epileptic shock I was flashing the screen on and off so much.
riyajhox
