Power consumption (wifi vs. 3g)?
elai1108
89
4
This question has been asked before but it was back in March so I wanted to get input from TBolt users who have direct experience.
Which connection uses more battery - Wifi or 3g?
Thanks in advance!
WiFi uses a little more than 3G from what i've noticed but WiFi uses a lot less than 4G. For me though WiFi doesnt use much more and my WiFi is way faster than 3G. So if I'm looking for speed but battery saving i'll use WiFi when i'm at home.
wifi is supposedly the least taxing. If you want your 3g to be better then put it in 3g only mode so it's not scanning for 4g.
This is just an observation from my point of view. I'm sure it varies a lot from person to person.
I am seldom in a 4G spot. My previous phones sucked battery when using WiFi, so I used 3G all the time on the Thunderbolt. I experimented for a few days with WiFi, and found the Thunderbolt WiFi to be very efficient. I now never turn it off unless I am on the car/motorcycle (no need to it to keep searching for a connection). It appears that it saves a bit of battery. And if it isn't, it is faster then the 3G connection which is all I normally get.
I keep my Bolt while I'm at home on my wifi. I noticed when on 3g my battery was getting drained VERY fast. I tried wifi, in my case it has been less of a battery hog. Hope you find the answer you are looking for.
Reactions: elai1108
I live in a 3G area but use wifi @ home. I dont see any noticeble difference in battery useage.
Attempting to debate with a person who has abandoned reason is like giving medicine to the dead. -
It depends on the signal of WiFi and 3G. In my house, WiFi is super strong and the 3g signal is weaker so I get better results with WiFi.
Reactions: elai1108
Thanks for all the input.
After running wifi at work (where 4G is spotty at best) as well as at home for a few days, my battery life seems to be much better than 3G in both locations.
Yea, for sure. I've gotten up to 21 hours on a stock battery while on wifi, but have only hit near 16-18 if you starting adding long 3g stints. 4g, I dunno since I only get it at work. Just to be clear, those numbers are all maxes, my personal bests, far from averages.
wifi is way less taxing than 4g, i can't say about 3g as i haven't been in a non-4g area yet :) .keep this in mind, wifi is designed to send and receive from a distance of 150' at the most. 3g and 4g have the power to send/receive over a couple of miles. which radio do you think uses the most power?
ecomranx32
