Power Control widget on PWGB v2.0b3
bxojr
138
19
I'm running PWGB v2.0b3. I can add the Power Control widget to my home screen, but the widget is blank (no icons) and doesn't do anything. I've deleted and re-added it multiple times with the same result. Has anybody else seen this with PWGB? Any ideas on how to fix it?
Have you tried rebooting the phone with the blank power widget on the screen? That worked for me when i first flashed.
Where did you get the Power Control Widget from? Also do you know if/how to get the CM7 calendar to work with this ROM?
EDIT: Ok... I found the widget you are talking about... But I still would like to know about the Calendar.
Just long press down anywhere on the screen that has space and a box will open up with options ie: Widgets, Shortcuts, Folders Walpapers... choose Widgets and scroll down near the bottom and you will see Power Control, press on that and it should appear on your screen...but note that it might be blank boxes at first and you may need to reboot to fix that.
Edit-- OOps didnt see your edit in there..well maybe someone else can use the info ;)
Reactions: sushiguy732
I had the same trouble. My icons showed up after about five minutes without a reboot. They have been fine ever since.
Good to know. I figured i was just going to have to get used to the buttons in the pulldown (which arent that inconvenient, but still...)
Anneyugwu2012
