An up arrow beside a down arrow usually means APN or mobile network but I didnt think Power Control had that selection like Swtch or Extended Controls does.
I installed CM6 RC2, and had to re-install the power control widget. That's when it showed up, right beside wi-fi. How do I do a screenshot?
It is a up arrow beside a down arrow.
Never seen that one on the power control widget... looks like the one under the 3G symbol on the notification bar that denotes data traffic (send/receive). What happens when you press on that toggle control?
OK I understand that controls Sync, but which specifically syncing are we talking about? Be cause I got a push "facebook message" how exactly do I deactivate or disable that is annoying at midnight!
