Pre-installed screen protector
Most tempered glass protectors suck, I don't see why it would be a deal breaker for s10
I have one that's been pretty good and it isn't an expensive brand. Hasn't scratched, chipped or cracked since October and it looks great.
I went back to have a look at the ones on display in a Carrier store (3) and they had the screen protector on and there was no hole.
Buying direct from Samsung gets you a clear case and a protective film as per the website.
In the box
Galaxy S10 Series
Galaxy S10eDeviceData CableTravel AdapterEjection PinUSB Connector (OTG)Earphones sound by AKGQuick Start GuidePattern CoverProtective Film
Galaxy S10DeviceData CableTravel AdapterEjection PinUSB Connector (OTG)Earphones sound by AKGQuick Start GuideClear CoverProtective Film
Galaxy S10+DeviceData CableTravel AdapterEjection PinUSB Connector (OTG)Earphones sound by AKGQuick Start GuideClear CoverProtective Film
In the box
Galaxy S10 Series
It says clear cover protective film I don't think you get a case and protector? But I am hoping they all have the protector. Now I am upset I didn't look while in Best Buy. They didn't even have any cases yet. I am calling them back to ask. But yes whitestone is the only glass one that will work supposedly and is supposed to be very good. I will just keep what's on the phone.
Whitestone Dome glass screen protector should work via their video - https://www.youtube.com/watch?v=bHloKE7zlwg
Do they have a normal installation video that isn't fast forwarded? Looks like they bumped the price up to $70 from $60. Seems like too much to pay but I have always liked having a glass protector on my phone. Hoping other companies figure it out and release some cheaper options.
Search for Whitestone Dome glass on youtube and you should see plenty of installation videos. I'm sure the process is the same. Right now it's $50 on Amazon for the S10+, $70 for a 2 pack - https://www.amazon.com/Dome-Glass-U...ag=hawk-future-20&ascsubtag=UUacUvbUpU6477539
I wish they would make up their mind LOL! I read yes than no and a guy doing the unboxing said no but I figured maybe it was cause his was a review unit.
Samsung has said they will all have them, so I would take their word over a reviewers review unit.
Cool! So I won't have to spend 30 bucks at the Kiosk in the mall for Zagg I want to get the new popsocket and an extra case or two.
for now I'm going stay with the preinstalled screen protector on the s10 that come on the phone
Me too! So now after I go to Best Buy next Friday I don't have to worry about going to the mall down the street I can go straight home and set up and play with my phone.
Exactly just going shop around for case but I'm not liking what I see yet , looking slim type
Just order a basic clear one on Amazon for like 12 bucks. This way you got something to protect it while you decide on the long term one!
For what it's worth I have used this same Spigen protector on every phone since I can remember. It's a TPU case so it's light and very slim but it has always held up to drops and provides good enough protection. It's slightly raised around the bezel as well and you can't beat the price. I always go with black phones so it blends well.
https://www.amazon.com/Spigen-Rugged-Designed-Samsung-Galaxy/dp/B07MJQYDYB/ref=pd_lpo_vtph_107_lp_t_3?_encoding=UTF8&psc=1&refRID=K6MEQWHYXEE77SG73M80
If you can easily peel it off, it's the normal packaging protector, not a screen protector. A plastic screen protector takes at least a little digging with your nail, if not a knife blade, to get under it and start lifting it off. (And a glass rotector definitely needs more than a fingernail.)
....knife blade!
Looks like good option, you know if it works with wireless charging no problem?
dmflowsjalallodhi
